Formato de archivo inesperado sketchup
Si se puede descargar ahora pero no lo pude abrir, tal vez @colin pueda recuperar el archivo o parte de el.
Hi guys !! , its posible to view this file , not open with Sketchup 2021 , thanks !!!
It doesn’t look promising for that file. Looks like about half of it is just zeroes. Do you have the .skb backup file?
Is there a folder where those backups are located? thanks!!
Normally the .skb file is created in the same folder where you saved the .skp file.
Thanks for the quick response, apparently the backup was not made and that file is the only one that arrived, inside you can see data and a header, but it was to know if something could be saved, best regards
Maybe @colin can extract something useful but I wouldn’t be holding my breath. Where were you saving the file?
The file was saved on a file server and just the day’s backup was complete but that file was corrupted in the previous backups, I suppose we will have to change some policies or maybe do two incremental backups per day if there are many changes.
I would suggest changing the policy to include saving the file on an internal drive and then copying it to the file server instead of working on the file directly on the server.
I couldn’t recover anything in the scene, but did recover materials and components. Look in the components tray to see if there are any components that would help you to rebuild the scene quickly.
That seems to be a random grab of data from your drive. Do you have an SKB backup file in the same folder as the SKP?
Thanks Colin!! This was a great help to me, I am very grateful!
No, the backup file was not recorded, I will see if I can change the program options to make backup copies, thanks again!
NECESITO AYUDA URGENTEEE
Este es el link, no tengo copia de respaldo ni versiones anteriores, solo ese archivo https://drive.google.com/file/d/1f_ecPX4FyTLb548IUz36QLurw387rC-9/view?usp=drive_link
Necesito ayuda con un archivo me sale “ESTE ARCHIVO NO PARECE SER MODELO DE SKETCHUP” es importantisimo, por favor.!!!
https://drive.google.com/drive/folders/1thoHy1rD3ZzO-P47ZrOd98bdRw4ImaGT?usp=sharing
ayudaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
What version of SketchUp are you using? There is no 2022 Free Plan as you put in your forum profile. Please correct your forum profile.
You have to make the SketchUp file accessible if you want us to help you.
Hola, tengo el mismo problema, ojalĂĄ puedas ayudarme
este es el link de mi archivo
The files is mostly filled with zeros. Where have you been saving the file as you’ve been working on it? Directly to One Drive?
Your forum profile says you are using SketchUp 2021. Is that a cracked version?
Do you have the .skb backup version of the file? Share it.
No tengo la copia de seguridad y por error eliminé el archivo y el que te he enviado es lo que pude recuperar.
Translated by Google:
That’s unfortunate. There’s nothing to recover from that file.
Again,
