Forestr's Gallery
This is my gallery where I post things I modeled in SketchUp.
For this post, some of my models are made recently, while others are very old (9 years ago-present). Most aren’t finished, but I figured I’d share anyways.
3 Stair Skate Spot
Skate Park
Fingerboarding Park
Concrete%20Spot4
Adjustable Element Flatbar Replica Fingerboarding Rail
Low Height
Medium Height
Maximum Height
Fingerboard%20Rail%20Design2
Futuristic Oceanic House Concept
Futuristic%20House%20copy2
Gold Indoor Skate Park
Skate Park
Tile Banks
Sculpture
Sculpture
5 Stair Handrail
House Concept
Ice Cream Sculpture Skate Spot
Skate Park
Skate Spot
Skate Park
Skate Park
Art%20Park%20%231%20(2)%20copy%202
Skate Park
Skate Park
Skate Park / Skate Shop
Skate Spot
large_thumbnail-4
Skate Park
Skate Park
Arizona%20Skate%20Plaza
Indoor Skate Park
Building Concept
It has an underground section & has sky bridges.
Skate Spot
large_thumbnail-1
Skate Spot
large_thumbnail-2
Skate Park
large_thumbnail
Skate Spot
The sculpture is a spiral from the top view & the side view. Pretty weird.
Untitled10
Skate Park
Couch
Underground Housing Community Concept
Skate Spot
Untitled2
3D Oak Trees (Drawn in SketchUp)
Skate Park
Skate Park
Skate Park
Skate Park
Skate Park
Skate%20Park5
19%20PM
Skate Park
Fisheye Angles
Skate%20Park%20Design8
Skate Park Stage Concept
Skate Park Speed Draw (Modeled in one day/about 10 hours?)
Sculpture for Skateboarding
Skate Spot Concept
Watermelon Bowl Concept
Skate Park
Tech Deck Park
Shade Structure
Moon Terrain
Skate Spot Rendering
Hemispherical Bathroom Mirror
Skate Spot Concept
Skate Spot
Handrail
Sculpture
Untitled3%20copy
Skate Spot
Skate Spot
I drew this ball pit today.
I drew this skate spot today.
Nice, have you had any luck with UE/Unity and the Skatepark yet?
Unfortunately, no… I’m still in the process of learning how to make video games. I’m hoping to make something similar to EA Skate. The main obstacles in my way are becoming proficient at Blender for motion capture/animations, coding, and Unity for game design.
Yes motion capture is very difficult and expensive! I would just stick with rigging it’s much easier and low key. You can bypass the blender part UE for rigging, it may be easier. Otherwise make sure to pick up rigify for Blender, its free.
https://docs.unrealengine.com/latest/INT/Engine/Content/Tools/MayaRiggingTool/RigTool_Rigging/#skeletoncreation
https://docs.unity3d.com/Manual/BlenderAndRigify.html
I wasn’t aware about how expensive motion capture was… I found a MOCAP system for $2,300. I’ll definitely stick to rigging! :joy: Thanks for showing me about rigify. You’ve just helped me a lot. :+1:
Yes, with the computer, software, cameras and other gear (as well as the space) you will struggle to do it for less than £10,000.
For coding start here: https://www.codecademy.com/learn/all
Then move onto Codepen: https://codepen.io/
By then you can decide if you want to invest in some classes or if you want to carry on with free material. Although HTML/CSS is not relevant to the game work you want it will be easier to get to grips with before progressing to another language.
I’m making street components. I’m going to make a couple variations for each, then start drawing building components and stuff. They’re like blocks, so i can make different arrangements.
Minimalist Sink
sink3
Skate Spot
Minimalist House
56%20PM
Beach House
Minimalist House
Tiny House Half-Pipe
33%20PM
Underground City (Uses grid of houses for structural support)
Minimalist Lounge Chair
Spiral Staircase (helix-shaped staircase w/central newel pole)
Helical Staircase (spiral-shaped staircase w/no central newel pole)
I just got the ClothWorks extension and had some fun making pillowcases, blankets, and curtains.
Untitled_Scene%202
I made this terrain by creating a mesh from a heightmap in Blender, then importing the mesh into SketchUp. From there, I added the water, the beach house, some vegetation (from Darrell Smith :+1: on the 3D Warehouse), and textured it all, then I rendered it with Twilight V2.
Prototype skater for a skateboarding videogame… The skateboard was drawn in SketchUp.
What about a folding 2x4? They fold with hinges, and could be screwed shut. There could be multiple lengths. For example, 8’ long, 6’ long, 4’ long, and 2’ long. The holes could be mechanically threaded, so it’d be a super tight grip. They could save tons of space. And they’re reusable… kinda like Legos. The design is from a dream I had about reducing the volume of building materials… Upon waking up, I decided to make a conceptual drawing of it.
Well, on a low tech level, there’s conventional metal stud construction that dominates commercial construction, and only barely showing up in residential construction. On a higher tech level, take a look at the “Cellophane House” that Kieran Timberlake temporarily built in the courtyard of MOMA in NYC ten years ago. I don’t think they invented the framing system, IIRC, they found an existing one and adapted it. Being bolted together, after the show was over, they simply disassembled the thing.
If the design really relies on hinges, the result would be quite unstable, and the fourth face would be rather superfluous if it is in no way connected to the first one at the corner. Whereas to bending the sections on site, it would require some quite heavy equipment. Welding it together would also be quite a demanding operation if carried out on site. Commercial metal construction uses either the basically u-shaped metal studs as described by RTCool, or then rectangular hollow sections (RHS) that are by nature much more rigid. Welded sections are best manufactured under factory conditions.
That’s true. The cost of fabricating the folding studs would be costly, but it’d be cool if there was a way to make this concept work. I was thinking about doing some research on different types of hinges to find the best option. I haven’t drawn the latches to close the stud yet. It’s just a conceptual sketch. Realistically, it might be an unstable construction material, but I figured I’d share my idea.
I think houses that can be disassembled and reassembled are a really useful idea. Imagine being able to disassemble your house, put it in a truck, and assemble it in a new location when you move. It’d also be cool if the building material allowed people to change their floor plan by moving around or adding rooms.
Well, if you want to read more about it, KieranTimerlake produced a book on the Cellophane House. In the book they tell more about the construction which they say is an “off the shelf” system of assembly from Bosch Rexroth. Looks like they have a million or so parts to choose from. A maker could have quite a time with all that stuff.
There is also, KieranTimberlake’s manifesto book “Refabricating Architecture on prefabrication in archtecture.”
As a matter of disclosure, Steve Kieran was my graduate school thesis project advisor, but I haven’t worked for his firm or any such thing after that. In fact, at the time, he was still an employee, along with Jim Timberlake, at Venturi, Rauch, Scott Brown, and hadn’t gotten into all this prefabrication stuff.
Modern Building at Night
Fingerboarding Park
