I’ve noticed this in the past year when I quit sketchup. I will file close all the models to quit out of or try to shutdown my computer and SketchUp will be unresponsive and not fully quit out. I especially notice it because my internal fan will turn on as if it was requiring a lot of power.
I end up doing a force quit but was wondering if this is a known issue or if it is just my computer.
Hey Dan! Do you see this every time? I see it on occasion, but not regularly, so not sure why that is happening.
If you see it every time, try disabling ruby as a start, then you might at least be able to trace the problem to a plugin if it quits properly with ruby off.
Thanks Tyson…it is almost every time so I figured it may be a plugin but haven’t had the time to check into it…I’ll see if that helps and hopefully see which plugin is causing the issue.
