SketchUp Application Not Responding on Quit
Every time I try to close Sketchup, I get an error message “Application Not Responding” and have to force quit the program. EVERY. SINGLE. TIME.
I am using 2019.3 since SU Podium does not work with 2020. Anyone else have this problem on a MAC??
Hang on quit is almost always due to an extension misbehaving. Try disabling them half at a time and see if the problem goes away.
Be sure to have the right version of SU podium, that problem( force quit) was solved right after the release of 19.2
What version do you have?
I have 19.3. removing the previous versions of SU Podium is a bit of a struggle. Is there any place to find directions to properly remove a previous version of SU Podium?
SU Podium is one of the extensions that puts itself into the system library, and not the user library. You can choose Finder’s Go menu, Go to Folder… and paste this in:
/Library/Application Support/SketchUp 2019/SketchUp/plugins
Watch out for alternate versions being in there.
