Force "List Selection" by previously determined value?
Hey guys, I’m wondering if there is a way to utilise a previously determined value to force a selection from a dropdown list?
IE: If A=“VALUE” then pre-select “VALUE” in the later dropdown list.
from: Help Center: Dynamic Component supported functions
CHOOSE(index,value1,value2, ...valueN)
The CHOOSE function returns a value from a list of parameters at the location of the index value. This function allows you to create a single drop-down list that drives multiple attribute changes at once.
Example:
=CHOOSE(2,"Blue","Red","Green")
The previous example results in “Red.”
Use CHOOSE and OPTIONINDEX together as a mechanism to assign different values depending on a user’s choice in the Component Options dialog box. For example, if the Component Options dialog box allows the user to choose different materials to assign to a component (and the price changes depending on material chosen), the formula for MSRP might be:
=CHOOSE(OPTIONINDEX("Material"), 100, 150, 200)
The previous example returns 100, 150, or 200 depending on the material chosen in the Component Options dialog box.
Also see this thread:
