I am using SU 2024 version 14.6.1 on a 2020 27" iMac. I’m finding that the 3D text feature works only on the Regular and Bold versions of fonts that have several other variations. Specifically I need to use Neue Plak Compressed Extra Bold (Neue Plak has 48 variations), but the same problem exists with other fonts as well. The desired font shows up correctly in he preview window (the one where you enter text) but when brought into the model it defaults to either regular or bold. Is there a fix for this?
Sorry. the variation I need is Compressed Extra Black. You are showing TrueType fonts. I have open type fonts. I tried changing the one variation I need to True Type, and installed that, but Sketchup didn’t recognize it. I can’t get the whole 48-variation list on my screen at once, but here’s a screenshot:
Yes. Windows uses TTF fonts normally.
I wonder if this is a Mac issue. @colin might have some insight as might @MikeWayzovski.
How did you change the variation you need from OTF to TTF?
I used an online converter, fontconverter.io.
OK.
Anything different if you install this set of TTF fonts? I know there isn’t the specific one that you are trying to use but just for trouble shooting.
Hmmm… I think we’ll need to wait for Colin.
Do you have SketchUp 2023 installed? Any different behavior in that version?
Sorry. I think it must be an Apple vs Windows thing but Colin can probably tell us.
okay. I’m leaving this for today, but thanks for your help.
I presume you are not using an Apple computer.
Correct. I’m using a PC. I used to use both but found Mac to be annoying. (YMMV)
I just checked and the entire Bahnschrift family as installed on my machine is available in SketchUp 2027. Time to update maybe.
Bahnschrift is one of the fonts with many (hobbyist?) versions circulating, with some that have been problematic with SketchUp. If updating to 2027 won’t fix it I don’t know how you could verify that you are using the same version of Bahnschrift as @DaveR …
BTW, looking at Dave’s screen recording, the font outlines seem to be badly drawn if the user wants a good 3D object out of them. 2D screen use or printing would probably not care about the overlaps.
