I’m trying to mirror or flip a line. I went the help file which states that when you select the geometry and go to the context menu there should be a “Flip Along” option. I’m not seeing that. What am I doing wrong?
Loose geometry can’t be flipped. Select your line and group it with Edit > Make Group. Don’t forget to ungroup later to avoid unnecessary errors.
More precisely, a single edge, arc or polyline can’t be flipped. Loose geometry can be flipped along but there needs to be more than one entity selected. The alternate method using the Scale tool can be used, though.
To DaveR’s point…
Outstanding. Thank you.
