Hi All,
I have a question about Flextools Fixed Window. I can’t find out how to make horizontal divisions in this window type. Anyone knows how to do this?
Thanks in advance!
Hi All,
Thanks in advance!
Have you tried to double click on the component and select one of the windows inside it? There should be more dynamic components options for that. (I’m not at the computer now so I can’t not record a video for you)
Anyway I ping @Yoni , I’m sure he can help you
Hi, thank you for your advice! I found the trick. First I have to “interact” on the glass. Then there will be a horizontal and vertical division. I don’t know the english terms for the vertical and horizontal “pieces of wood”? In Dutch we call the horizontal “dorpel” and the vertical “stijl” but I didn’t find the right translation. In the component it is called “Sash”. When I double-click on that I can enter the desired measurements.
Hi, Glad you solved it!
Clicking with the Interact Tool will cycle through different division configurations, the first being the one you wanted.
Double clicking and selecting the insides as @rtches suggested will take you to the Sash settings where you can change the ‘# Divisions’ settings too (as in the screenshot you put up).
Yes that worked ![]()
Thanks for your reply!
