Hello! Sorry if this is a basic issue, but I haven’t been able to find a clear answer on this in any videos or other forum posts. I’m essentially brand new to Sketchup (just installed Pro 2026) but I have previous experience with AutoCad and Fusion360 (never full-time, only drawing up odd jobs here and there).
I’m playing around with building my own little library of dynamic cabinets in styles that I generally build so I can just quickly drag and drop and adjust my dimensions. So far everything is working good and I’m understanding how to adjust my parameters so everything scales properly when I adjust dimensions. The only issue I’ve come across is if I want to adjust the overall depth of my cabinet, everything moves correctly except the groove/dado (1/2” wide x 3/8” deep and set in 1/2” from the back of my gable/side) will scale.
For example if I wanted to adjust the cabinet depth from 24” to 12”, everything will move and scale together correctly, except now my dado/groove will only be 1/4” wide instead of 1/2” wide, and only be 1/4” from the back instead of 1/2” from the back.
Is there a way to lock the size and location of a cutout in a component to avoid this issue?
Thanks in advance for your help!
Let me know if there’s more info/detail you need.
See thread for other photo
