So I was wondering - normally when you double click & highlight the circumference of a circle you can right click and find ‘find centre’ - however it doesn’t always come up, I’m assuming after editing the circle this feature disappears.
Anyone know how to ‘find centre’ when the circle has already been edited?
If you select the circle and look in Entity Info, what does it say? The circle can sometimes be broken up into individual edges or be converted to a curve, e.g. when using follow me or when scaling it.
Or there’s a plugin by Chris Fulmer to find the apparent centre by picking any two edges of the curve or exploded or edited circle or arc. CLF Arc center point finder - search the extension warehouse to find it.
Select 3-point Arc, Check if the number of segments is the same as your exploded curve,pick three points on the exploded curve , right click; find centre
