Hello, what would be the best way to fill in a corner like this where the rounded edges are 2 different sizes?
Thank you!
I think I would draw a slopping edge to close up the side with the step and then use curviloft to blend between the two curves.
If you don’t have access to extensions you can use ctrl with pushpull to overlap the extrusions so you can intersect them and delete the bits you don’t want.
