Hello. I am a new sketchup user. I have a design that will not open, it says “file won’t open” when I try to open it up. I had it saved in an external drive at work, took my computer home for the weekend, and now am back at the office trying to open it.
Depends on file size. If it is 16 Mb or smaller you can drag and drop it into your forum post. If it is larger, share it via a cloud service (Dropbox, GoogleDrive, WeTransfer…) and post the link here.
Good! Now quit saving directly to an external drive. Save it to the drive inside the computer. If you need to be able to work on the file from different machines, copy it from the internal drive to the external drive and when you need to work on it, copy it from the external drive to the internal drive. Or use your Trimble Connect storage after saving the file internally.
