i have made a renders of a kitchen. i would like to have feedback on the the renders and how i can improve it.
Thank you
Are the cabinet doors supposed to be so glossy? It doesn’t seem like a practical finish in a kitchen that would actually be used.
The section cut through the canister on the top shelf and the baskets is not good. I would move the section plane and/or move the objects so they aren’t cut through.
What renderer are you using? Why are you using SketchUp 2023? Is it a cr acked version?
That’s a really great start, better than most I see.
I’d look to see about rounding the edges of things - everything is very sharp.
Also see if you can apply some surface variance/texture to the painted walls
Try to do something with what is outside of the window - the blurry HDRI texture and doesn’t really appear to match the lighting. I’d probably deliberately put it out of focus and blow it out.
Hi Dave,
Thank you for writing the feedback. I appreciate it.
Yes it is. People prefer gloss finish in the kitchen here.
Iam using Vray
I will try moving the section plane and see.
Hi Adam,
Thank you for writing your feedback. I appreciate it.
I have taken note of the all points you have mentioned.
