Is there somebody can tell me why the fast keys are not available anymore in 2017?
They are still available in SketchUp 2017. Most users find that when keyboard shortcuts donât work, itâs due to SketchUp being installed incorrectly. The user hasnât used Run as administrator after right clicking on the installer. Try that and see if you have better luck.
By Fast Keys you mean short cuts ?
Have you installed SketchUp correctly ?( Right clicked on the installer file and choose : Run as Administrator)
When in doubt, go to the installer file ( probably in downloads) and right click on it , choose âRun as Administratorâ and ,when prompted, choose the repair option.
Thank you guys but still not working
Please set out ALL of the steps you have taken to install SketchUp, in step-by-step detailâŠ
yes Thanks
What?
I did the set up set by step and still not accessible, is this something that i need to check in preferences?
What steps?
TIG asked you to tell us exactly which steps you took. Is there some reason you arenât telling us?
If SketchUp is installed correctly, the keyboard shortcuts will work.
Are you using a translated SU version? The Swedish translation uses the same word for Undo and Redo (which of course is completely wrong and a mistake only an idiot would make) which causes the shortcuts associated with these phrases to malfunction.
What shortcuts are not working? If itâs every single one itâs most likely a driver issue.
Mostly i use move and scale
Envoyé de mon iPhone
You are not helping us to help you.
You are missing the point of many of the questions in the replies.
SoâŠ
How did you install SketchUp ?
Its installer exe file must be run by using the context-menu,
âRun as administratorâ.
Doing the installation any other way can cause several weird problems, like yoursâŠ
Vous ne nous aidez pas Ă vous aider.
Vous manquez beaucoup de questions dans les réponses.
AlorsâŠ
Comment avez-vous installé SketchUp?
Son fichier exe dâinstallation doit ĂȘtre exĂ©cutĂ© en utilisant le menu contextuel,
«ExĂ©cuter en tant quâadministrateur».
Faire lâinstallation dâune autre maniĂšre peut causer plusieurs problĂšmes Ă©tranges, comme le vĂŽtreâŠ
If i remember i did exactely what you said i Will redo everything again at the beginning
Thank you
