Failed at the first hurdle!
Hi all,
Just trying to get started with SketchUp Web. So, reading the Help Centre for under “Creating and Editing Models” heading, it says:
To create a new model in SketchUp for Web, you start with a template. Follow these steps:
*1. In SketchUp for Web, click the Open Model/Preferences icon *
2. On the panel that appears, click the New Model icon . The following figure shows your template options.
3. Select a template that reflects your desired units of measure. Your options include feet and inches, meters, or millimeters. After you click an option, your new model opens in SketchUp for Web, ready for you to begin 3D-modeling.
But when I choose ‘New’ icon, no templates appear. Just the empty screen with the man image and the axes. Can anyone help please? This is a bit of a frustrating start…
Ian
That is your modeling space containing your template, with the setting(s) in it that you chose.
Say if you have chosen millimeters (something you can still change at any time), you just start modeling. As you go along you can change any settings the way you like them to be. At the end you save your model with these settings. Just start drawing stuf with the ‘Line’ tool. Make a few mistakes, no harm done. If you don’t start you won’t get anywhere with SketchUp.
Thanks Dan. Didn’t realize I’d skipped that step by choosing millimeters earlier. Onward and upward!
That little man is to give you a sense of scale, the size you are drawing. Best if you model real size (scale 1:1 so to speak). You cannot set scale in SketchUp. You can however model things in a different scale. But that is (most of the time) pointless
