Face Won't Intersect With Edges
Hi everyone. I’m in the middle of a project and I’ve come across this problem. No matter what I try to do the edges and this face won’t intersect. I’ve tried all the intersect commands, copying the wireframe and pasting it in a different file, manually redrawing all the edges, using the Make Face plugin, copying the whole thing and pasting in the same place… Nothing works.
Can someone please help me figure this out? I’d be very grateful. I’ve come across this issue many times before but I was always able to fix it. Can’t understand what causes this.
Faces.skp (1.4 MB)
can u plz save that file in 2015 and attach. As i cant open ur file in 2015 its 2016 version
There you go!
Faces 2015.skp (1.4 MB)
The way i do this. I deleted the selection. And redraw the edges from the walls.
Afterwards I redraw the necessary edges to fill the big faces.
See this topic for a possible explanation off this behaviour
Thanks a lot! :thumbsup:
Indeed, you seem to have tripped this long-standing bug. The only way I could find to repair the model was to delete all the edges bounding the offending faces and redraw them.
refer this video u will get the solution
