Pretty new to SketchUp and i have a specific problem that i’m not finding a tutorial for.
I need 3D letters for a video with this precise bevel. The bevel needs to go around and create D.
But i seems to always create a flat surface and with a bit of a crooked side.
There are some things Autofold will have trouble resolving. You can draw in the edges between the outside and the cnterline either before or after you raise it.
I made a quickie example. In this case I had to add a few on the inside instead but the idea is the same. I softened edges afterward.
You can use a plugin like curviloft if you have to do it with a lot of letters, it will do the job for you, just select the edges, run the plugin and it will create the mesh automatically.
