Extra surfaces added?
This happened to my file, noticed it after editing a component. Closed the file, closed sketchup, even restarted computer… it doesn’t go away anymore. Luckily I always have some recent backups, but still asking myself what happened. Did anybody experience the same and maybe solved it?
Share the .skp file so we can see what you are working with.
Hi Dave.
It’s hard to tell exactly but I’m guessing you perhaps exploded a group or some groups causing geometry to merge. All of the walls and floor are ungrouped geometry and that geometry has been given a tag. Exploding tagged objects would result in the geometry inheriting the tag(s).
There’s a lot of incorrect tag usage in the model.
There are also graphical issues caused by having parts of the model spread out by almost half a kilometer. The sawtooth edges to the materials on faces is evidence of this.
Move everything closer to the origin and get rid of stuff you don’t absolutely need. Probably don’t really need three copies of that island where they are. One ought to be enough and again, keep it close to the origin.
Here, as an example, I’ve deleted all of the content strung out to the left of the origin and moved the center of the three rooms close to the origin. Also set the Camera to Perspective to place it at a reasonable distance from the model.
Is it really half a kilometer? :grinning_face_with_smiling_eyes:
The three copy’s I use to make the drawings for the calculation. I will never use Layout :wink:
However, the backup drawing works fine, it is an exact copy of his one. I never saw anything like this happen.
But now you mention it, I indeed exploded a tag group.
Thanks for looking into it!
It’s headed for that. Over 300 meters.
Still don’t need three copies of it.
It’s handy to make a drawing with different views. And all these separate pieces are under one tag, which I switch off during drawing. Really Dave, it never slowed anything down. Since everything is working on Silicon, Sketchup works like a dream. That said, that’s also the reason I don’t dare to switch to 26 or 27, still on 24. Which works perfectly fine for my usage.
Your call. There are numerous other examples on the forum of the same graphical issue your model displays and the fix has always been the same. Keep the entire model close to the origin. If you don’t want to do that it’s your choice. I showed you the difference in the appearance of your model by reducing the area is covers.
