I’m currently working on a bike path, whenever I make a cut in the piece, on any face, sketchup creates 3 faces on top in place of the cut, and sometimes the cut doesn’t even work, there’s a floating line. How to solve?
Whenever I move an object sketchup break and keep loading for a few seconds. (I believe this is due to the weight of the project, there is a lot of useless stuff that I didn’t delete)
I expect a large part of your first problem comes from incorrect tag usage. You should leave Untagged active at all times. The pencil icon should be at Untagged.
It looks like you’re getting geometry merging with other geometry and the incorrect tag usage doesn’t help.Use groups and components more. I removed the tags from all the edges and faces in your model.
I also purged unused stuff from your model. That stuff will impact performance and there’s no reason to hoard it all.
The purging reduced the file size by 86.5%.
See how this works for you. ap50 purged.skp (12.9 MB)
