File corrupt? Lines disappearing
Would anyone be willing to assist with this file that seems to be faulty? Lines are being drawn and then disappearing and not saving.
tolland 5-5 copy.skp (4.6 MB)
Well, looking at your model I see incorrect tag usage. You are giving raw geometry tags which should be reserved for groups and components. All edges and faces should be created and remain untagged. With the geometry selected the Tag field in Entity Info is blank indicating more than one tag is assigned to the selection. It should say Untagged.
Fixing the incorrect tag usage shows this:
You should be using groups and components as you model, too.
You could also be seeing graphical issues in your model because you have it scattered out over a relatively large area. Keep the model close to the origin.
Are you stilll using SketchUp 2023?
Ok yes, we knew the ungrouped items were a problem. This all makes sense. Model is 2026. Thank you.
I guess before you call it a bug or corrupted file you should fix the lack of grouping and also fix the incorrect tag usage. Again, move the model close to the origin. Get rid of extraneous stuff, too.
Please update your forum profile. Thanks.
