Extra geometry in section plane view
I used section plane to get a view of my model. But some extra geometries (probably fragments of existing object) come in the way while rendering. This doesn’t happen when I am not using section plane. I attached images. Can someone help me with this? Thank you!
Check the correct orientation of the faces, white outwards.
It worked! Thank you so much! You people are the best. Can you tell me why this happened?
You have to learn to model correctly, with white faces outwards.
“To produce correct results most render programs require normals (fronts of faces) to be consistently orientated outwards, i.e. visible to the camera.”
If you want to know more, do a search for ‘normals’ and ‘faces orientation’, there are a lots of tutorials
Thank you so much for helping me out! Really.
