Extension / Plugin menus not appearing
Some extensions/plugins I use have a corner menu that requires settings to complete an action, and are not showing up in SU 2024. For example Roundcorner by Fredo. It’s working in 2023 but not 2024, and I have the same issue with other plugins from other developers.
I have updated all the plugins and updated SU and am running LibFredo v.15
When I click the plugin the top of my window flashes but nothing happens.
Below is an image of the menu from 2023 which is not appearing in 2024.
Did you also install the Sketchucation Extension Store tool? It is required for license management of Fredo’s extensions. Did you activate the license for the extension in SketchUp 2024? Did you install SketchUp 2024 correctly? That requires you to right click on the installer and choose Run as administrator.
BTW, your forum profile says you are using SketchUp 2021, please update that along with the other information if it has changed.
