Since upgrading Sketchup Pro Fredo's pluins is not working?
*Anyone else having this problem? Yes, I purchased them.
I didn’t have a problem getting his extenstions to work in SU2024.
Did you install the extensions in SketchUp 2024? Did you also install the Sketchucation ExtensionStore? Did you activate the licenses after installing the extensions in SketchUp 2024?
If you did all this correctly, you would have first installed the Sketchucation ExtensionStore and used it to automatically install your bundle of extensions from Sketchucation including Fredo6’s.
Yes Dave tried a lot of different things? Do I need to unistall first ?
What different things, exactly?
Uninstall what?
Since I have no idea what you tried, maybe removing all the extensions first would be a good idea. Then download and install the Sketchucation ExtensionStore and use it to install Fredo6’s extensions. Make sure you also install the current LibFredo6.
I did reinstall all the plugins but did not uninstall the ones that were put in automatically by the Sketchup Extensions manage
Did you install the Sketchucation ExtensionStore tool? Fredo6’s extensions will not work without it.
yes I did that first as the program asked when I first opened the upgrade.
I bought the bundle maybe I missed one somewhere. The block comes up for the Fredo upgrade but it is blank
What do you mean by that? SketchUp won’t ask you to install the Sketchucation ExtensionStore tool.
Did you copy your old extensions from the previous version?
When I opened extension manager it did ask me to install it?
SketchUp will not ask you to install the Sketchucation ExtensionStore. If you had installed an old version it might tell you it’s not supported.
I am pretty sure it did Dave, you know when you open it it says with check marks these extensions of plug ins need to be upgraded? Maybe it didn’t work, I can check it.
Did you copy the old extensions from the previous SketchUp version?
No, but it could have not upgraded the one in the .rbz folder?
I will check with Sketchucation site, thanks Dave. Let you know if it works.
Each major version of SketchUp installs as a separate application. The Sketchucation ExtensionStore would not have been automatically installed in SketchUp 2024 and the SketchUp ExtensionManager would not tell you that the Sketchucation ExtensionStore needs to be updated.
