So… Just gone to use ‘RoundCorner’, and it’s decided to tell me my trial has expired, even though it’s the bought version and has been for a long while, and when I try to install the licence I get this message:
First thing I would do is make sure the Sketchucation Extension Store is up to date along with LibFredo6 and Round Corner. That’s all easily done with the Sketchucation Extension Store tool. Next, do what the message directed. Delete the license file and revalidate it.
Obviously I completely understand what you mean here, but for the benefit of anyone else reading this who may not have the skillz, could you expand a little on the process?
I’ve had the same issue with Fredo’s plug-ins, I tried to contact him but had no luck, I deleted the files that say do not delete on the folder that contains the signature file, then uninstalled all the plug-ins and installed them again, after doing that the licenses were recognized. Also go to the sketchucation website and manage your licenses, delete the seats you have assigned before installing the plug-ins again.
Open the Sketchucation ExtensionStore tool and make sure you have the latest versions of the Sketchucation tool, LibFredo6, and the extensions for which you have licenses installed. Then quit and restart SketchUp.
Having similar issues here. Copied my plug in folder over to 2024 and then the fight was on…Uninstalled Sketchucation plug in and reinstalled it. I uninstalled all Fredo plug ins and am now reinstalling them…I keep getting the same pop up window:
Go get the latest version of the Sketchucation Extension Store tool installed and use it to install LibFredo6 and the extensions for which you have licenses. When you’ve finished, quit and restart SketchUp.
Also, did you install SketchUp 2024 correctly? That requires right clicking on the downloaded installer and selecting Run as administrator.
2024 has been runnnig for several weeks…just finally got around to installing the plug ins I had in 2023…not sure how to check it now? But I have installed several plug ins and everything worked fine before the copy.
Quit SketchUp 2024. Find the installer in your Downloads folder. Right click on it, choose Run as administrator, and then choose the Repair option when it is presented. After the installtion/repair finishes do a cold reboot of the computer and then open SketchUp again.
I got it to work…your suggestion of the sketchucation update FIRST and then the Fredo Lib seemed to fix it…now I just got debug the Profile Builder plug in…
