Fredo Corner is outdated and won't install
I was using Fredo Corner then was told it had expired and I needed to purchase. I went to the Sketchucation site and saw that a perpetual license is $25. No problem. The problem is there is NO place to actually pay for it. There is a donation button but that is akin to a “Patreon” monthly donation. I just want to purchase it! Help.
Look at the instructions on the first page of the FredoCorner thread. You’ll need to have the sketchucation Extension Store tool installed also. You can get that under Resources at the top of the Sketchucation forum page.
I appreciate the response but there are multiple Fredo Corner threads. Which one has the instructions. BTW, I did install the sketchUcation manager.
This one: https://sketchucation.com/forums/viewtopic.php?f=323&t=70149
It would make more sense to post this on Sketchucation where Fredo would see it.
Thanks! I went there and it gives the general instructions on how to install. Nothing on how to pay. Do you have any idea as to how I do that? I’m happy to support the cause but I don’t like to pay in perpetuity, I’d be happy to pay the $25. I posted a note but I suppose it will take a bit to get a response. Unfortunately these things always seem to happen when you really need to use the program now! Thanks again for your response.
Install the extension. Then go to the Tools menu>Fredo Collection>Round Corner>license
See:
https://sketchucation.com/forums/viewtopic.php?f=323&t=70149&p=669537#p669537
Hi, I have been using Fredo Corner without problem for the last year or so and have paid for perpetual license. A message just popped up to say I needed to reinsall the upgrade. I just reinstalled it using the latest download from the Sketchucation site but npw its not showing in the menu or tools (although it does show in Extensions Manager). I have restarted Sketchup a couple of times but its still not visible, can anyone help please ?
Just to check, did you install LibFredo6 v12.4?
Which version of Sketchup do you have. Your profile says 2019.
If you run SU2021 or SU2022, the best way to find out if there are errors, is to
  • Open the Ruby Console
  • Close Sketchup (with the Ruby console opened).
  • Restart Sketchup - the Ruby console will open
  • all potential error messages related to the loading of plugins would appear in the Ruby console.
Thanks for the quick reply. I’m using SU2021 now.
I have followedf those instructions, Ruby console screenshot is attached (I can’t see anything relating to Fredo Corner listed)
Do you see FredoCorner in menu Tools > Fredo6 Collection?
No, I looked there - only Fredo Scale is showing
How did you go about installing FredoCorner when you updated it? have you quit and restarted SketchUp?
I uninstalled it from the Extension Manager within Sketchup, then closed Sketchup, then I installed the new download (which I downloaded from Sketchucation site), then opened Sketchup again and installed the new download again using the Extension Manager. It’s showing the Extension Manager but not in tools or listed in the Menu options. I have restarted Sketchup a couple of times but its still not showing.
You shouldn’t need to uninstall it before installing the update. Check the Extension Manager to see if it shows as disabled. Or does it show at all in Extension Manager?
You really ought to use the Sketchucation Extension Store to install extensions from Sketchucation. It’ll help you keep them up to date and when you upgrade to the next version or move to a new computer you can use it to install your bundle of extensions from Sketchucation to make sure you have the latest versions. Mine is telling me that CLothworks has an available update. If there were more than one extension needing updating I could click an Update All button and it would take care of it for me.
Thanks. It is showing in Extension Manager and I can’t see anything to indicate that it is disabled (see attached screenshot).
I have just tried uninstalled it from Extension Manager and then used Sketchucation Extension Store to install it as you suggested (using the menu from within Sketchup). Unfortunately this has not worked and is showing in the Extension Manager but not in tools or Menu options :frowning:
I don’t think you answered this.
Look at the Home page.
@Box is correct. It doesn’t appear that you’ve answered that question.
I do already have LibFredo6 v12.4 installed (see screenshot). Would you recommend that I try to install again from within the Extensions Store
yes, its definitely enabled and has been the whole time…
