Extension Manager Fail 25.0.634
While attempting to troubleshoot an extension, I disabled all the extensions in the Extension Manager except the one I was working with. (or so I thought) I closed the SketchUp window and restarted. On opening, I was presented with a nag to download something to be able to run Curviloft. I looked at the extension manager and found the Fredo extensions and several others were still enabled. I selected disable for them, applied changes, and restarted SketchUp, but they were still enabled. I repaired SketchUp, but that did not cure the issue. Can anyone duplicate this? If not, I have an issue with my PC that needs to be dealt with.
I sometimes have problems like this with the sketchucation ones - try disabling them in the sketchucation extension manager first if you have used that .
That is a thought, I will give it a try. THX
yep, same observation, turning them off in the sketchucation manager did the trick.
Same here. I kept getting warnings that libFredo6 was required and all the extensions refused to disable until I did them via the SketchUcation plugin manager extension.
