Extension licensing issues
Since I’ve updated to Sketchup 2023 I’ve had chronic licensing issues with some extensions.
I’ve verified that I did indeed purchase the extensions but I keep getting a no license error.
If go to the Extension Warehouse page for the extensions all I see is the Install button with no option to purchase which tells me I must have a license
I’ve tried every combination I can think of short of wiping my install completely and starting over including quitting, deleting, sign-in/out, etc. but the extensions don’t find a license.
Any suggestions from the hive mind?
Paul
OSX 13.5.1 on M2 Mini
Sketchup Pro 23.1.241
Which extensions specifically?
Please update your forum profile with that info.
I hate to put a developer’s name on the forum this way. Is this a private discussion?
I’ll update my profile
Paul
it’s not a private discussion it’s a public forum.
but you need to understand that unless we know what extension is causing trouble, nobody can help you. just give the link to the extension or its name, the developer might well be on this forum on a daily basis.
there is no problem saying “hey XYZ, I can’t use your tool, can you help”?
edit : you can contact most extension developers straight from the extension page, so I assume that if you’re posting for help here, it didn’t bear fruits. help us help you :slight_smile:
Once again I’m having the issue where Eneroth Component Replacer, which I have a license for, suddenly tells me I’m not licensed.
I noticed it after I updated OSX to Sonoma 14.5.
If I go to the extension warehouse to buy a new license I only get the option to Install so I’m stuck.
Any ideas?
@colin
Paul
OSX 14.5 on M2 Mac Mini
Sketchup Pro 24.0.483
It would help if you identify the extension. Maybe @colin will have time to look in and then reset the license. Keep in mind that it is a holiday weekend so it might not be until Tuesday.
OK thanks for the tip
Paul
There is a particular problem, that I’ve fixed yet again. Two of your extensions would have had problems, they should work now.
Thanks. Why does it keep reoccurring?
Regards
Paul
It’s a long standing bug in the license system, that still hasn’t been taken care of. It’s trivial to work around the issue, maybe that’s why it hasn’t been seen as being urgent.
From the customer perspective, poor update experience is should be at the top of the “urgent” priorities.
I’m having the same problem with 2DXY_Site Survey.
I have a license but it wont install it because it won’t update.
Also many extentions that I have purchased in the past are not showing up on the list.
Someone with Sketchup may have to fix some setting on your account
That’s what fixed me
Paul
I fixed the issue, it should be ok now.
