Is there a way to export TAGS into Word?
check this thread
several solutions, at least one that allows an export to excel.
excel, word, just one step from one to the other
For some reason I can’t open this in Sketch Up 2026. It tries to open a Sketch Up Make version?
What are you trying to open?
Your profile says you are using SketchUp 2017 Make.
I use SU 2017 and v2026 pro
Add that to your forum profile.
And again, what are you trying to open? If it’s the 5D+ extension, you don’t open it. You need to install it using the Extension Manager. Same as with any other extension.
Unfortunately it isn’t showing up in my Extension Manager
It won’t until you install it. Open the Extension Manager and click on Install Extension at the bottom of the window. Find the downloaded extension file and proceed from there.
You are under the assumption that I don’t know how to find and load an extension. I’m telling you, it isn’t showing up.
Can you send me a version that will run in SU 2026
I’m not making any assumptions. I’m working with the little information you’ve provided. I just downloaded and installed the extension for the first time in SketchUp 2026. It showed up as expected right between 3D Text Editor and AI Assistant.
Your profile shows you are using Windows 10. SketchUp 2026 isn’t supported on Windows 10. Maybe that has something to do with why you aren’t seeing the extension.
Actually, it must take time for it to appear in my version. I was able to install the extension. I do appreciate everyone’s help.
We must have the same version since you’re using SketchUp 2026 and I’m using SketchUp 2026. Might have something to do with your computer. As you can see it took about a second on mine to appear.
Well, I got it loaded and it works! Woo Hoo lol
Got it to work, Fantastic! Thank you.
