Hello. I have exported a rendered Sketchup to Layout and because it looked like the colour was bleeding I changed to Hybrid and tried Vector but still looks messy with line/colour. Is this as good as it gets?
Thanks
I hadn’t - just checked and it was on medium. Thank you so much!
Is this what you are seeing in LayOut or in the export from LayOut? It’s generally a good idea to leave Edit resolution set to Medium or even Low depending on your graphics card’s capabilities.
I changed it to high which looked better but will use medium if that works better generally.
As long as your computer can handle displaying the viewports with the High setting, knock yourself out. If things start to slow down, go back to Medium or even Low. Remember that doesn’t reflect the output quality.
Ok thanks, it seemed to. But will bear that in mind.
