Export to AutoCAD lines missing
Evening all
A couple of questions - the first is probably really easy … how do I turn the lines back on in a component that I have downloaded from the warehouse (screenshot below)
Then the second question - how do I make circular objects export with an outline to AutoCAD. At the moment any curves come out without any edges at all (again screenshot below)
Thank you
There are a few ways one can “hide” the edge linework.
STYLES : check the Style menu make sure the edge style is turned on.
05%20PM
HIDE : Entities in SketchUp can also be selected and hid by using the hide feature. You can see hidden edgework by going to View > Hidden Geometry. This will show you all the hidden and softened edge work. You will want to select the edges you want to show and select Edit > Unhide
Soften/Smooth Edges : To get the one surface look from a combination of mulitple surfaces, users often use the Soften Edges feature. This will visually remove linework from connected surefaces. You can reverse the look of this by selecting the smoothed surface and activating the Soften/Smooth dialog (Window > Soften Edges). By shifting the dialog slider to the left, it will remove the soften/smooth characteristics of the surface.
Under the Style menu, you will be able to select Profile to show the profile silhouette of the curved surfaces
Hope this helps
CD
Sorry - just saw this - thank you, all fixed !
