HI, I received a Sketchup file which I want to export the faces as dxf file so i can use in Fusion 360.
The export option seems to export the view as a dxf. I selected a face but it will not just export that face.
Can it be done ?
Thank you
Can it be done ?
Thank you
Delete what you don’t want to export first. I would save the file with a different name, first so you don’t risk losing the rest of the model.
Or you could set up a scene in SketchUp showing just the face you want, use that scene in LayOut and export the .dxf form LayOut.
It would be a good idea to update to the current version of SketchUp and LayOut.
You should possibly be using 3D export instead of 2D. The latter exports a vector image of your screen.
