Export from layout to .dwg III
Hey there,
after having several issues in finding out how to export to .dwg out of layout:
  1. I don’t know if I am right, but it seems to me that there is no possibility to easyly export dashed lines coming from a sketchup viewport: In Sketchup I have drawn geometry and assigned them to a tag. The tag was visualized with dashes. I created a scene in xray mode, and another scene with wireframe visualization.
    Then in Layout created a viewport of the skechup file with the xray scene and another page with a viewport of the wireframe scene, both I set it to vektor mode. I refreshed the model reference and saved the layout file. The dashed lines were visualized in both scenes correctly in sketchup, while in Layout they are not, in both pages/viewports. Also when exporting to dwg out of layout no dashed lines…
    When going to raster mode too, hybrid too. ( I got that now). That means to me that i have no possibility to export a in sketchup drawn geometry with dashed lines per layout to dwg, also with dashed lines…am I right? Please tell me if i made an error or didn’t understand something wrong…
    The only way I could generate dashed dwg-lines was to redraw the geometry in layout itself and formating them dashy…
  2. I have set the viewport to scale 1:50. Then I went to dwg export - then checked the checkbox to export for sketchup. Everything fine, the export worked but when opening with a dwg-viewer the scale is 5 times smaller than it should be. (In sketchup 1 drew in cm). Is there no easy way to get a 1:1 dwg-file out of layout directly?
    I would be happy if you could help me if you notice something a false routine…
    Also I would be happy if you could describe me your handling how to export dwg files…perhaps there is a easier way then over layout, perhaps a sketchup extension, or somehow…
    Thank you for your replies
    yours
    spb
What kind of export settings did you use?
As to dashes, did you check in AutoCad what the line type scaling variables looked like?
Screenshot 2021-08-07 181930
Instead of Autocad I use the Autodesk dwg Viewer called DWG True View Application. It is only a viewer and you cannot scale line types…
Ah, in sketchup the tag was set with the first dashed line entry:
Screenshot 2021-08-07 183907
Did I something wrong in my workflow? / Does sketchup / layout support the dashed line dwg export out of layout?
Thank you for your time…
The last setting “Export for SketchUp” is the one that confuses your scale. It creates a DWG file of your LayOut page and puts all the objects into Model space, at the scale of the LayOut page. It is often a very practical setting, but usually you have to open the model in CAD and scale the whole thing to get it to full scale.
Yes I understand. I suggested intuitively it should be like this.
  • checked for Export to model space in 1:1, perhaps with an additional dialog to set a scale factor…that would be useful becaus I would not have to adjust with another software (me I unfortunately don’t have Autocad)
  • perhaps another checkbox for export to paper space with scale like in sketchup
    But I think that is another question…
My initial question was if a expierienced expert - SU- user can export dashed lines out of Layout (lines that come out of a SU-viewport) to dwg…? (disregarding the proper scale for now)
…Sorry perhaps I did not explain my question good enough, or I misworded something…
I read your post as a series of questions (the answer might be interrelated, in fact). I’ll try to look at the dashes thing.
Yes, you are right! Thank you very much…I am really curios about it…
I tried exporting one file of my own.First with the Export for SketchUp box unchecked. I looked at my dashdot lines with the List command in TrueView. Their linetype was dashdot, and they had a line scale factor of 20. On screen they looked solid, but I guess that with the correct linetype scale values and a correct global ltscale value they would look OK. I wonder if this is an inches/metric (I use millimeters) conversion issue behind the scenes but I have seen this with other applications too.
With the Export to SketchUp box checked, everything looked almost exactly like on my LayOut page, with correct dashdots visible.
