It doesn’t crash anymore for the most part but man it is super buggy…One time it exports…one time it doesn’t with the same scene. Sometimes I have to just push pull something to like wake it back up. This really needs to be fixed. I only need edges. Everything is off but edges. Sometimes it exports like 20% of the scene…sometimes it exports 80% of the scene and just ignores one thing for some reason…Sometimes it just works. I have tried version 12-2018 DWG types and the verify hidden line option on and off…Nothing else is on so not sure what else to do. It also crashed twice today but at least it does not crash like it did when 2024 was first released. The Sketchup screenshot and the dwg below have an example of what I am getting…Where did the stair go?
to get an accurate answer please upload the .SKP file.
Can you post the model and the DWG you get from it? You show both 2D and 3D export dialogs, which one is the one that fails?
What if you turn your CAD background to white? Sometime in the past I have got CAD lines set to RGB colour 0,0,0 fromthe exporter. In AutoCad that remains black even on a black background.
Not sure where you see 3d export. It is all 2d export. This happens in all my sketchup models. I have exported a million times in multiple Sketchup versions. Been thru the NLS warning era thing for 6 years+…2023 worked fine but images were having an issue…I just need this working… How do I submit this bug to Sketchup Tech support? My cad backround is an off black so that can use the color 250. If it was coming in black I would see it. I open the cad files and sometimes they are just empty (happening right now actually…)
Why don’t you just upload your model so people here can try it out…
Sometimes words and images just can’t get to the heart of what is going on. Please share an example skp so we can investigate.
The options dialog images you posted. This is for the “3D Model” export:
And this is for the “2D Graphic”
Please open a case at https://help.sketchup.com/en/contact-support/technical-question/form
Once created you’ll have a way to share the model with us and we can investigate what is going wrong here.
Thanks,
Dan
No that window is when I check the “Always prompt for hidden line options”
