When I click “File”>“Export”>“3D Model…” I get an immediate crash. It even happens when I have one simple object in my model. Just looking for guidance on how to resolve this issue.
Thank you
Thank you
Hello. Which version of SketchUp are you using? Has this issue started recently or have you always had it?
See you are using pro which means you have options other SU. What are you doing??
Thanks for the reply.
I just noticed this issue this week however it’s been at least a month since I last used this feature. Since this issue recently started it leads met to believe that it has to do with some other program that I have recently updated.
Yesterday I updated to Version 17.2.2555 in hopes of resolving the problem but I’m still having the same issue.
Could this be cause by incompatible versions of JAVA, Runtime C++ or anti-virus software?
I’m trying to export to .dwg.
any (new) plugins/extensions installed?
AMD Radeon graphics card driver updated? if yes, check Windows software uninstall panel for a software called “Play.TV” and uninstall if found.
All,
I uninstalled and reinstalled Sketchup 2017 and that fixed the problem.
Thank you
