When I want to explode the project I imported, the program closes itself?
Share the .skp file so we can see what you are working with an help you.
Untitled.skp (2.9 MB)
First I imported the work into sketchup. Then I used âarchitect toolsâ for 2 dimensions and exported. Later, when I imported it again, I saw that explode closed the program.
What I want to do is just close the open ends with âedge toolsâ (which it doesnât do for all ends) and create surfaces
And also the ends that I had previously closed with âedge toolsâ are now open again. So my previous work is not showing for open ends now and work is back to the beginning
it does close on my computer too - 2022 version, no bug splat
I canât look at it at the moment, but the normal reason for a non bugsplat crash is too many segments.
Why do you want to explode it, why not open for editing and fix the edges that way. While in there break it down into smaller Groups.
So I might ask, why does it show so many open ends when I put it in sketchup for a drawing that works fine in the autocad file? And what can I do for it?
All i want to do is cover the surfaces
I get a Bug Splat when I try to explode it, too. As @Box indicated, this is likely due to having too many segments. Reducing it into smaller groups could help. When you imported it did it come in with a bunch of tags?
For face creation SketchUp is not tolerant of gaps in edges. That doesnât seem to be an issue with AutoCAD probably because it isnât creating faces from the loops of edges.
Thank you for all answers. Iâll try
The work was sent to cloud. You said you can find it from import&export from the other forum. But on my screen there are only these options. Where can I find the work I have imported?
This looks like a problem we have fixed in the latest internal builds. I canât give a date for when there will be a new update.
Meanwhile, here is a 2020 version file of the group exploded.
exploded.skp (13.2 MB)
Thank you so much! Thank you so much! Open ends problem is also solved
