Error: We're having an issue reaching Google drive
We’re using SketchUp for Schools in my classes. Several students regularly have a problem saving their files. When they click the Save button, they get an Error message that says “We’re having an issue reaching Google Drive. Please download a backup file. While you try that, we’ll be working on this issue.”
This does not affect all students, and I’ve never had the problem (teacher). They are logged into their school Google accounts when this happens.
After some experimenting, I discovered they can save their files using Save As. So there’s a workaround, but it would be great to figure out what’s happening so it can be prevented.
Thanks!
Note: similar to Issue reaching Trimble connect, but that was a different problem.
It is hard to say for sure but it is possible for a student to get this error (but still be able to “Save As”) if the model they are working on has been moved or deleted since being opened. If you are still having the issue, I can investigate some on our end to see if there is a proper bug to fix. At the very least the error message could probably use some work.
I had trouble saving my room model on Sketchup For Schools, first time it has save to my Google Drive, but then it says “Error: We’re having an issue reaching Google Drive. Please download a backup file. While you try that, we’ll be working on this issue.”, I had a problem for the first time but I received an error message for the second time, I hoped if SketchUp Team Member will possibly fix this. Jason Ta-Room #1(3).pdf (82.1 KB)
@glennied Thank you for bringing this to our attention. Our team is looking into this, and I’m glad that you’ve found a workaround for the time being.
For our knowledge, are your students currently working remotely and relying on home internet connections?
@jason.ta Were you completely unable to save your files?
My apologies for the delayed reply. I don’t believe the files are being moved or deleted since being opened, but can’t say that with 100% certainty. We are still having this problem, and I’d estimate it affects at least 1/4 of the students. I’m now teaching them a 3-step process: 1) Save, 2) Save As, and 3) Download. We very rarely have to go to the 3rd step. It seems odd that the Save As works when Save doesn’t - that seems to imply it’s more a file name problem than a connection to their Google drives.
My students are all working from home. Connection quality ranges from excellent to poor. For the record, even with poor connections, SketchUp can take a relatively long time (but no more than a couple minutes) to start, but performance is excellent after startup.
I’ve got the same problem except I can’t access any other drive to save the students work???
Can you please elaborate?
Was this working for you before?
Are you able to login?
Do you see any errors?
What browser/OS are you on?
Hi @Gazz, I just wanted to circle back around on this and see if you are still getting the error you mentioned. If so, we need additional information to help you out. Can you please let us know the information that marwanobeidat asked about so we can see if we can come up with a solution for you?
Hi, we are experiencing saving errors as well.
Error messages that students are getting when working on projects:
a) When trying to save:
" ERROR We’re having an issue reaching Google Drive. Please download a backup file. While you try that, we’ll be working on this issue."
b) And when working in general:
" We were unable to retrieve your data, please select “Retry” below to try again."
Contrary to earlier in this thread, using “Save As” does not help
The only workaround is to download an .skp file (that does work), and opening it up in SketchUp Pro. (Luckily we do have machines that can run SketchUp Pro.)
I took a screen recording:
Why is this still an unresolved glitch after so long?
Hi @a.digiovanni, thanks for the post. Sorry to hear that the save bug is affecting you although if the save as solution is not working I am guessing that it is a different issue affecting you. We are currently seeing a significant uptick in this sort of issue and are investigating a potential solution. Hopefully we will be able to roll out the fix soon.
In the meantime, a solid workaround that we suggest is to refresh the page every 45 minutes or so. That seems to fix the issue in the majority of cases.
As a best practice, please have your students go to settings and turn on the Autosave, I have it auto save at 2 or 3 minutes.
This is still occurring for me as a teacher as well as a lot of my students, very frustrating.
