Editing component info
I enter names and comments when I define a component. These are easy to edit later. Sometimes I also enter URLs. But I can’t find where these can be changed/deleted later. Can someone tell me where/how to do that?
Are you referring to editing the component description? Select the component in the In Model components. You can then edit its description.
As I wrote, I have no problem changing the name and description in a component as you show here. However, I can’t find access to the advanced attributes so that I can make changes here.
Entity Info
Thank you a lot for taking the time to make this little informative video. The explanation in plain text would be to tell me to go to entity info and click on the little pull down menu on the right side to access editing of advanced attributes.
Anyway, problem solved. Thank you again.
