Whenever I load this skp.File L10±+Airplane+4.2+Airframe+v2.0 (2).skp (1023.7 KB)
from the 3D warehouse . I open the components from the menu on the right I can see all the components listed Spar, Wing plan , Wing rib etc, But I cannot load any of them or edit the demensions. I also tried to ungroup the 3D model when it loads but it will not let me, Is this because I just have Sketchup Free? Or am I not doing something?
There’s quite a bit of nesting of components in the model. Double click on them with the Select tool until you get to the raw geometry. Then you can edit it.
Okay, it works , like you said , but what about the individual components on the righthand menu bar can I load one them and edit each one individually.?
The components are coming into the model but due to the incorrect scaling of the model, they are tiny compared to the size of the overall model so they don’t show.
Here’s the spar doubler in the model. Note it’s more than 46 feet long.
If you’re just going to edit the components, delete the huge version of the airplane from the model space. Drag in the components and use Zoom Extents to zoom in on them.
