Dynamic Block Not Working Inside Group – Auto Opening Issue
Hi, how are you? I have a question about dynamic blocks. I’m creating sinks/tanks with automatic openings, and I configure everything correctly, but the block only works when the countertop is ungrouped.
I’d like to keep it grouped, but in that case, I have to use the traditional method of intersecting faces manually.
Is there any setting that allows me to use dynamic blocks within a group without needing to ungroup them for the automatic opening to work?
Unfortunately, that is how it is. Hole-cutting components only cut a single face that is in the same context as the component.
Oh, that’s a shame I was hoping there would be a solution, but that’s okay. Thank you so much for your guidance, Anssi.
