Hi,
I would like to get the DropGC tool, but I have the 2022 Sketchup version. Do you know if this tool still work in this versión? Any other similar plugin? Thanks
DropGC works fine with 2022. Ignore the text and install it.
Thanks for your response, it run fine. I tried to use DropGC tool for trees from the laubwerk tool but I couldn’t. Do you know if this is possible? Thanks
What happened when you tried?
I select de tree, then press the DropGC button but don´t work whit this object
Share the SketchUp file so we can see what you’ve got. If the tree component is heavy (lots of geometry) you just need to wait. Your profile indicates you have an integrated graphics card which isn’t the best for SketchUp.
Thank you for your response
