Extension 3Darcstudio tree maker
3darcstudio
#1
Hi people! I downloaded the 3Darcstudio tree maker extension and when I try to create a new tree, the slot where all the types of trees should be, shows no options whatsoever, its empty. Help please.
Thank you!
#2
Hello. Where did you download the extension from? The separate website dedicated to it or Extension Warehouse? I see you have SketchUp 2017. The SketchUp Compatibility of the plugin does not support versions higher than 2015, maybe that’s the case (although I did manage to use it in 2016).
#3
Hi, it was a compatibility issue. I solved the problem by running the extension on Sketch up 2016, create the file, modify it, saving the file and then import it to the Sketch up 2017.
Thank you for your response!
#4
