Just upgraded to SUP2021 and I was able to install one extension from 2020, but wondered if anyone has had any luck with Wudworx, which I use for dovetails and mortise and tenon joints. On their site, they say they don’t support it.
I use the Wudworx tools all the time. It works just fine in SU2021.
Thanks, good to know. Did you transfer them from an earlier version? Having a devil of a time finding where they are on my system. And searching in Extension Manager brings no joy.
Since the Wudworx tools haven’t changed in years I do just bring them over from the previous version. You should be able to find it in User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins. Copy it to the same location in 2021. I assume you are going from 2019 to 2021 since your profile says you are using 2019. Maybe you could update your profile while you’re here. ![]()
Thanks, my setup was a little different but I was able to install it nonetheless.
