Hi there,
I have an extruded cylinder that I want to drape a line pattern onto the side of.
I have used Window > Soften edges to create one selectable surface around the cylinder (with no vertical lines), and am trying to use the Sandbox > Drape tool to drape my 2D lines onto the curve.
I’ve used the Sandbox > Drape tool before successfully with surfaces created through Sandbox from Contours, but I cannot get it to work in this instance, and I am wondering if it’s because the cylinder was not created through Sandbox?
I’ve noticed that when trying to use the drape tool, it is turning red when I hover over my cylinder as my item to drape onto, whereas previously with sandbox from contours meshes it stayed white.
Any suggestions / tips / advice much appreciated?
Thanks,
Lisa
