Disappearing Layouts Palette
I have a very frustrating problem I would like to resolve.
I use SketchUp 17-Pro on a 27 inch iMac. I also have a 24 inch monitor linked to this iMac.
When I select LAYERS from the WINDOW menu there is a checkmark (√) alongside the Layers indicating that the Layers Panel is active. The problem is, try as I may, I sometimes simply can’t find it. I go back to the WINDOW menu to toggle it on & off in the hopes I will see some indication of it flash on my screen but still no luck.
Where does it disappear to and how do I make it visible?
Try ‘Arrange Panels’ in the window menu
I don’t see any such menu item…??
It’s probably off-screen due to the difference in your monitors. Have you tried Preferences->Workspace->Reset Workspace? That will close all your open inspector windows and hopefully when you reopen them they will be on screen again (I haven’t had your problem on my single-screen MacBook Pro so I can’t guarantee that’s the fix :thinking:).
Ah! LayOut, not SketchUp. The Category tag misled me… I’ve Edited the topic title to fix this.
Preferences>Workspace>ResetWorkspace did the trick.
Thanks guys!
I was mislead by the title :smile:
The OP meant SketchUp, after all! Changed the category back
To reset the Panels on a Mac:
Sketchup: [Preferences]->Workspace->Reset Workspace
LayOut: [Window]->Arrange Panels
