I’ve been having a weird issue with SketchUp menus, lately. Every time I open any of my sketchup projects, my menus (tags, scenes…) are not open, when I go into the windows menu there is a dash near the main ones I use, which usually means they are minimised, although they are nowhere to be seen. Then when I click on each one to open, none will open. So EVERYTIME I open a project, I need to go into preferences to reset the workspace. I cant understand why it’s not saving my workspace. please help
Is this a recent install of SketchUp on this computer? Do you use a second monitor at any time? Has anything changed on your computer recently (system update)?
I do use a monitor, but I always have, this is quite a recent problem I have, not sure if its due to 2023 version, I dont recall having the issue prior
This happens to me when I use an external monitor with my laptop (Macbook Pro M2 Max). If I go from working with just the laptop to then attaching the additional monitor, the mini-windows end up reduced and hidden at the very bottom of my laptop screen (I have the monitor set as main). I have ‘solved’ the problem by making sure I quit SU anytime I am moving between set-ups. I hope this helps. Actually, I hope it makes sense.
What happens when you close your MacBook Pro lid? Then when you open it do you still have the same problem. I use two monitors and I keep my Mac laptop closed. Everything seems to work OK
Ok guys, so according to all the comments, I have tried some things and here is what happened:
It seems that when I open a project purely on my Mac, the menus are there.
However, when I open a Sketchup project and I have my monitor connected, the menus do not show up. (@Chip_Cookie I did check around to see if anything was reduced and hidden, not the case)
But, I did go to the windows menu and clicked “hide dialog” then clicked again to " show dialog" and the menus appeared!!
so so happy, thank you all for the comments and the help
