Dimensions in layout.Pro 2020
Hi all,
Minor problem. see attached file. I want to be able to have a precise dimension shown instead of the figure being rounded out.Euro Decantor Dimensions and Text.layout (411.7 KB)
The dimensions you show attached to the model are done in SketchUp. If you want those dimensions to show more precise values (higher precision) then set the Precision higher in SketchUp.
Or you could use LayOut’s Dimension tool and set the Precision as high as you need there.
FWIW this is not a technical problem with LayOut.
Thanks again Dave for your help. Sorry about posting in the wrong section.
TGC,
This topic was automatically closed after 186 days. New replies are no longer allowed.
