Different wall colour in rendered scenes issue
Hi,
Hope someone can help. Vray renders wall in different colours. Orriginal wall colour is blue (image 1) but in another scene is grey. Same rendering parametres, even remove all lighting Dome or Sun still grey (imager 2). Any ideas what is wrong?
Thank you.
It looks like it could be the way the light is bounding off the walls from the window…which is normal that a color can appear different when the lighting changes. Do you have Auto-White Balance enabled in your camera settings? You can also try adjusting the white balance in an Adjustment Layer in the Frame Buffer. It’s not just the wall color but the room itself appears warmer in the second view.
Yes Auto White Balance was on, wihtout that looks bit better, could you able to guide me where that Adjustement Layer?
Thank you, just found a video on Youtube, how to correct colours after rendering. Hope it will be possible to get all images in same colour.
Good you found it. I almost always have to go in and adjust the exposure, white balance, light mix, etc. All good things to know how to do and good that you can do it right in the Frame Buffer and not have to exit out to Photoshop or sim.
Thank you for the advice, still not achieved the best result, but need to practice :blush:
Looks good. I’d also recommend, if it’s just the wall color you want to adjust separately from the rest of the view, to add a Material ID Color or Material Random Color channel prior to rendering.
Then in Photoshop (or similar app), you can quickly select the color (ie material) that you want…
… and adjust it independently from the rest of the render:
Thank you, that great option too. Today, I have rendered all scenes again, before check all material, possible it was some faces not reversed, and they created that green colour. Now it look macht better. Learn every day sometehing new, that is amazing tool.
Thanks for reporting back. I always forget to start with check for reversed faces as that is the most common cause of material problems.
Yes, you are right. Good luck.
