Hi all. I am working on an extension and wanted to get feedback if possible - mainly if this is something that could be of value to the community or it there are other, better workflows.
I love using sketchup to model and design and I usually use a Sketchup - Vray workflow, but I am finding I hit bottleknecks where sketchup isn’t designed for something or I have to add a new addon. Bevels are a common example.
I am working on a Live link between sketchup and Blender whereby I can model in sketchup and it will automatically link the model into Blender. I can then use blender to refine the model (texturing, modifiers, animation etc) and then choose what elements I want to be pushed back to my sketchup file.
An Example: I have a scene with a roof structure. I model the beam in Sketchup and it links to blender. In blender I can texture the object and apply an array modifier to the object as well as refine its geometry with bevels/something for the render. I then choose to link the array and texture back to sketchup but not the added geometry. In sketchup the array will show as a series of components.
I have attach a small video of my work in progress.
EDIT: someone pointed out to me that there was an extension named BlendUp several years ago. Will change the name in future updates.
It would be so useful to be able to add or refine details, unwrap, and create UV maps in Blender, and then automatically send the model to SketchUp.
There are already a few Blender extensions available, but they rely on sending the model to a server (Super3D conversion service) and then automatically importing an OBJ file from there (needs internet connection). To be avoided.
I had long hoped that the SketchUp team would create such a link via an extension like the one from Twinmotion.
On the Sketchup side, an object needs to be grouped or made a component before it links to blender - my thinking is that if you left the object loose it might create issues when edited in blender.
on the the blender side, you need to select what you want to be linked back (edited mesh, modifiers, textures) with checkboxes in the Object Properties Panel and click link. You don’t have to save to server or hard drive. The main reason I’ve done this is that I don’t want sketchup to automatically fill with dense geometry. I’m also considering having a Cap on how many faces an object can have in blender for it to send back or an “are you sure” checkbox. This way you can model a couch in Sketchup that fits perfect into the Sketchup - Layout workflow, and any over complicated edits in blender won’t break your Sketchup scene.
@mihai.s textures are definitely my next priority. I want to be able to texture in blender and then maybe only the UV and diffuse will be sent back to SketchUp. You’re more than welcome to make suggestions on how you might want to see this accomplished - thats the point of this thread.
It would also be useful to be able to automatically bake the base color (diffuse) upon export, although it is probably better to bake all the textures in Blender (either natively or, even better, using a good extension).
And it is best to avoid connecting to the internet—perhaps with the sole exception of the option to check for updates, and even then, only if you choose to do so. The Blender way.
Thanks for the feedback guys. only worked on a few things today. I managed to get the textures working in both: Sketchup to Blender and blender to Sketchup. The texture opens in Blender with mapping and co-ordinate nodes but is not unwrapped.
I configured the edge smoothness to be copied in both directions as shown in video.
I added a selection option in the modifiers tab so you can select what modifiers to transfer back to Sketchup
I am joining in on this thread.. Definitely interested in your project. I need to get myself back into Blender after many years absence but a sketchup/blender live link … oh yes
Thanks @markod . I’ve been trying progress out on a small project I’m working on and will post updates.
I also fell off blender for a while - I swapped to a Sketchup - Vray workflow due to the nature of the studio I was working at. Even though I’m back in Blender I still find SketchUp is faster for basic modeling and blocking out scenes.
I will probably be reaching out to do a bit of beta testing soon if you’re keen.
This would be wonderful. If you’re planning this as a paid extension I would happily pay a reasonable amount.
I love Blender, but SketchUp is just so much better/optimized for architectural work that I don’t really see them as rivals. I do some back and forth for basically two things: Geometry Nodes and Cycles. The SketchUp Importer add-on works reasonably well, but reflecting the small changes I make in Blender back to the main model in SketchUp is a pain point. If this one can solve that, I would be very happy.
It is live, but only for groups and components. Once something is grouped, every change inside it shows up in Blender almost instantly, including drawing new faces. Loose geometry is left out on purpose: SketchUp can’t track it reliably, and it would send half-finished shapes while you’re still drawing.
It already works both ways, just not automatically in the Blender to SketchUp direction. In Blender you choose what to send back per object (position, modifiers like Array or Subdivision, mesh edits, or materials and UVs), and each press of a button updates SketchUp. SketchUp then shows the result as a proxy, much like V-Ray proxies, and the original stays as a untouched hidden object - I am trying to make it link as a “Sketch2Blend originals” tag, so they stay out of the way.
I kept that direction manual deliberately. Dense Blender geometry can easily bog SketchUp down, and the one rule I won’t break is that working in Blender should never be able to damage your SketchUp file. My priority is to give the user as much control as possible, so that files and scenes don’t become a mess.
I’m currently working on a way of linking the scenes in Sketchup as a camera in Blender and wanted your feedback. Would you prefer each scene to be represented by a new camera or one camera and each scene is a keyframe on the timeline?
I never used the key frame trick, but I’m guessing that would not allow me to have different ratios, field of view etc per scene? So I’d prefer separate cameras.
last update for the day… this is camera progress. I haven’t tested it fully and there are a few errors when adjusting the camera in blender. I also need to overlay the 2 images later to confirm that they are matching
