I am a System Admin at a High School and am installing the SketchUp2015-x64.msi. I have deployed the software with a silent install but the teacher is requesting that it be done without desktop icons.
I have been unable to find this MSI’s Public Properties. I have tried the setting DESKTOPSHORTCUT=0 but it did not work and installed with desktop icons.
Can you list all the Public Properties for this MSI.
Note: I got the MSI by extracting the SketchUpMake-en-x64.exe wtih 7zip
Not sure if you’ve already figured this out for your environment, but I was able to edit the MSI with the Orca tool from Microsoft SDK and remove the Shortcut table rows for the desktop icons:
Install the Orca editor by double-clicking the Orca.msi file in the \Microsoft SDK\bin folder.
Right-click the MSI and choose “Edit with Orca”
Select the “Shortcut” tables. In the right-pane, you can right-click and choose “Drop Row” to remove the rows for desktopSketchUp.F(etc.), desktopLayout.F(etc.) and desktopStyelBuilder.F(etc.)
Click Save
If it does not work in your environment, you can always download or re-extract the original MSI to restore the default functionality.
