I just updated my Sketchup Pro subscription and downloaded the newest patch (Ver 23.2.340 64-Bit)
after updating, the del key no longer works when working with a model. I believe all of the quick keys are working. checked the Key Binding and it looks like Del Key is bound to Deleting. Oddly, when I type in some text while in sketchup, I can highlight and then hit Del key and it deletes the text.
But when highlighting lines and plans in the model and then hitting Del Key, nothing happens.
I too have lost my delete function. Update 23.1.340 64 bit windows 10. Both number pad delete and hotkey not working. If in edit menu dropdown the hotkey will work but otherwise nothing. Works fine in Layout. I love my delete key please help me get it back.
Thanks
I’m working on a new machine (paired with an update to the most recent version of Sketchup) and the “delete” key on the number pad won’t delete even when it does successfully delete text.
There is an existing bug report for the various keys that were not working. The known ones were fixed in the 2023.1.3 update, but I have been adding new examples to the bug report. I don’t know yet when the problems will be fixed.
Thanks for the Update Colin. Please keep us up to date as things progress. It is a big headache as I use the delete key regularly. Is there a way to go back an update or two in order to gain access to the del key again?
I experienced the same thing. Here is A solution that works.
Install the Windows PowerToys application which can be found here-
Start PowerToys and open the Keyboard Manager window. Here you can remap the Delete key to the Delete (Numpad) key and vice versa. This essentially swaps the keys and will resolve the problem until a permanent patch can be created.
